INTERIOR lights CUT OUT, CAN'T FIND FUSE!!!!! PLEASE HELP.
91talonontsi
49
Sep 16, 2004
chester springs, Pennsylvania
OK i did something stupid the other day! i was getting mad at the glove box light becuase it wouldn't turn off. so like a moron i cut the wires to the light! without taking off the bat. or even seperating the wires. of course when i cut through both with metal dikes it shorted and killed all of the interior light and also i guess it is the same fuse for the rear lights and corner lights!!! the cluster lights don't turn on anymore also the lights for the heater switches don't work either. i checked the fuse panel on the driver side under the dash. i looked at all of them just to make sure and they all looked fine. :confused: so i have no clue where the fuse is for this thing. :cry: so does anyone have any clue where it is?????? because i can't drive at night with no tail lights nor side markers!!!!
In the fuse box under the hood. At least thats where its at for me in my 2G turbo. Its in a little yellow thing. Two 10 amp fuses are in there. :talon:
ok i didn't check to hard under the hood but ill look. ill tell you guys if its not there..... :thumb:
yup it was there. thanks for relising my stupidity. it was right there in my face. if i only looked for 2 secs. o well i got it fixed. thanks
LOL classic cutting a hot and ground wire at the same time with metal clippers. i know ive done this about 257 times and counting.
i then found out why on movies when theyre dealing with disarming a bomb and they say "the red or the green wire" i used to say "cut them both at the same time idiots". i now know why they have to do it one at a time.
