intake problems???
92gs_918
Feb 25, 2010
tulsa, Oklahoma
ok, i have a 94 gs. 2 problems i think. first, alot of times when im coming to a stop and come out of gear, rpm's drop and car dies. starts right up afterwards though. any advice? second, say im in third driving along. when i left off the gas, its starts jerking. what the hell??? i have taken the throttle body apart and cleaned it up real good, it was horribly nasty. looked in the intake manifold, its nasty as well. i seafoamed it and its like its gotten worse. need a new intake manifold???
sounds like your bov isnt recirculating . and your intake manifold is probable filled with carbon cause of the egr. so take it off clean it out and dont hook back up the egr . i had to do that on my car because when i went to clean my throttle body i took a light and looked in there and say how bad it was
1G BISS Adjustment
Give this a try first.
Also if your BOV is venting to the atmosphere this will happen as well.
well, if i had a turbo, id try it, LOL....but im thinking its the IM all clogged up as well. pisses me off
it could be a fuel problem, like a clogged fuel filter. They are cheap and wouldn't hurt to change if it never has
Yep that would be my next set of advice:thumb: Never move onto huge things like changing your IM before taking care of all of the basic service needs of your motor. More often than not that will be the root of you problem.
yea thought about that. but at idle, its perfect. and the only time i have problems is when i let off the gas and/or after the motor is fully warmed up. going to change the fuel filter first though
