intake pipe/filter
sphinx0nine
99
Nov 13, 2003
Calgary,
So, i didnt know if i should put up this on the newbie or in the turbo section, so i figured this was the best places.
Problem is that the intake pipe.. on my stock system.. i had that ugly rubber part, that fitted on the 14g rather nice, but my intake for the turbo now its quite larger.. How does one go about settting the filter and the air sensor to one of this big turbos?
.. damn, what a stupid question.
I appreciate your help.
If you mean that you got a new hard-pipe intake for your stock 14b turbo and the intake's coupler is larger than the turbo inlet, you can use a small piece of radiator hose the right diameter (2.00" Inside diameter, 2.25" Outside diameter, I believe) as a spacer inside the intake's coupler. On the 2g original intake hose, there was already a spacer inside it; I don't know if the 1g hoses had these or not. If this doesn't work for you, a transition hose should.
nope thats not what i meant, but thanks for the reply
im have a garret 60-1 so the inlet for it its much bigger than the 14g
im thinkin im going to go with the dejon
thanks
CanadianTSi said:
So your saying you bought a bigger turbo and now you need a bigger intake (common sense)
Whats the real question??
real question was answered in the 2nd post. I was just looking for the most common solution wich was given to me by DGajre777.
Thanks for replying.
