Intake cam gear on exhaust shaft and vice versa
jahjahSQC
101
Jul 17, 2008
Winder, Georgia
I'm going to confirm when I get home but i tihnk i may have swapped my intake/exhaust cam gears on accident when i assembled my head.
Its a 7 bolt 2g motor
So this would lead me to 2 questions, would this cause the car to not run? or can the cams be swapped without concern?
and... if they can't be swapped... what are the chances i damaged anything?
nah. cams are in the right spot for sure, I've got the cam sensor installed and all. And yeah i see that its all good with my installation . cam gears are fine.
False alarm :)
intake cam has a slot for the cam sensor and the exhaust does not so you can not swap them cause the wont fit
