Installing GSC S3 cams
eclipse98gs-t
125
Jun 1, 2004
LIma, South America
Hi, I have a couple of questions about the installation of camshafts in a 2.0L engine. The camshafts are GSC S3 280/280 and have 11.7 lift, is this dangerous as the pistons can hit the valves? You need to do some work on the pistons? I'm using double springs Manley. I know I must be very careful with the springs installed height, which must be installed height?
thanks
As far as the valves hitting the pistons there is other info needed to be factored in.
Has the head been milled? If yes, How much?
Has the block been milled?
What pistons are being used?
Do you have over sized valves installed?
What head gasket and what thickness is being used?
A couple more questions need to be answered. What size valves are being used stock size or 1mm over? What pistons are in the motor? Are the pistons valve releifs machined for larger cams/valves?
Hey. Thanks for your replies, I appreciate your help.
Neither the head nor the block have been milled. Pistons are 8.5:1 JE at 0.50.
Valves are stock, not oversized. Head gasket is Cometic, 0.045 thickness. The pistons are not machined valve releifs, just that's what I know, if required to do that job.
Thanks
It is very rare to have a head that was not milled at some point in the past 20 odd years.
Measure the head thickness.
http://www.dsmtuners.com/forums/cyl...how-measure-4g63-cylinder-head-thickness.html
Are you sure the Head and block surfaces are correct for a Cometic/MLS head gasket?
http://www.dsmtuners.com/forums/new...face-4g63t-cylinder-head-mls-head-gasket.html
http://www.dsmtuners.com/forums/cyl...-deck-4g63-cast-iron-block.html#post152790451
Also you need to measure your piston to deck clearance.
http://www.dsmtuners.com/forums/cyl...heck-piston-deck-clearance.html#post152107571
You say that the pistons are not machined Valve relifes... so you are using a cast piston, like NPR?
But before that you say you have JE pistons, JE are a forged piston and should have a fully machined piston crown, if that is the case you should have machined valve releifs.
What part number Manley Duel Valve springs are installed? What seat pressure at what installed height?
Hey. I want to apologize because my English is not good, I'm using the google translator. I'm sure the head has not been milled. The pistons are JE and YES they have the relifes valves. The part number of the springs is "Manley 26115"
Here in Peru we can not measure the pressure of the springs, so I just want to know the proper height installation.
I hope my comments can help.
thanks
Sping info...
http://www.dsmtuners.com/forums/newbie-forum/341209-4g63t-valve-spring-info-2.html
Post #45 for your manley kit
*** NEW INFO***
The GSC3 cams will NOT work with the Manley springs
http://www.power-division.com/product.php?productid=16143&cat=285&page=1
The cams have a net lift of 11.7mm or
11.7 x .03937 = .4606
The manley springs have a max lift spec of .370 due to the outer spring, the inner would barley handle it.
So you need to decide to change to a diffrent spring set up, or go to less agressive cams.
But if you run the GSC3 cams on the Manley spring kit #26115, you will be breaking parts about on start up.
this is the kind of help I need! :thumb:
in this case, what springs should I buy?
according to the link you put, they do not recommend these cams for turbos less than 67mm, but I am using a GT3540R, there will be problems?
Thanks for your time bro!
Look at Beehive spring kits from Kiggley, Ferrea, or GSC
Those are just great for the cams you have chosen.!
Build it and run it!
