Installing CAS backwards, now can't boost past 2psi
Imp Pwr Online
127
Jul 26, 2002
concord, North Carolina
It's on a 3000GT but same deal, I put it on 180 degrees backwards and went from boosting at 30psi to 2. Even after I put it back in right. What did it break? Comp is 155 on all 6. Timing is dead on. Engine was even rebuilt, and turbos rebuilt. Same problem.
Make sure to check all of your boost source's for leaks. Also if the timing was 180 off check your plugs for fouling really bad or even to be closed. I had a friend who couldn't boost more than 2-3 psi and it ended up being a closed spark plug. I'm sure you check them when you compression tested but I thought I would throw that out. Also unhook your battery for about 10-15 minutes and your ECU then plug them back in and start the car. It might have to relearn some stuff from running so bad it probobly tried to advance and retard timing so much that it messed itself up.
turned out one of the 14bs was blown, so it would stall and allow the compressed air from teh good 14b to come out it's inlet.
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
