installed mbc and it wont lower the pxi below 12
From what I understand, you can’t lower your psi’s any less than what’s set on the actuator. And if I remember right stock 2nd gen are set at 12 psi’s.
I read on a honda sight that you could extend the wastegate arm and that would lower the boost. Somehow they cut the arm and thread it, then put in an adjustable link to make the arm longer or shorter. I have not tried this but you can go here and search. www.homemadeturbo.com
