n0va91TSI
- 267
- 0
- Mar 2, 2004
Honolulu,
Hawaii
When driving after I quickly let off the gas it stalls. It will idle without stalling but the idle is unusually low (500rpms)
I tapped off the fuel pressure regulator bottom tube (solid black) for the boost and tapped the lighting for the gauge to the black/yellow stereo wire which I was told is the dimmer wire.
Its a 94 tsi awd
Im thinking maybe I turned the knob on the back of the fuel pressure regulator? Would that cause this? If so What should i set it at?
The gauge works fine 18mm/hg at idle and boosts to just above 10psi. I dont have a boost controller.
The light on the gauge is working backwards with the dimmer. Meaning when I turn the level down on the main gauge cluster...the boost gauge light lowers.
The HVAC lighting harness was unpluged by accident when installing the gauge and I really dont want to take everything apart again unless it maybe the problem
I have an aftermarket alarm and catback that came with the car if the could affect anything
I have no idea why I am stalling and I need my car to work. HELP!
Its a 94 tsi awd
