injectors
wes97tsi
Jun 5, 2012
Lakeland, Florida
Thanks guys. So If I put my Stock fuel injectors back in It will start up and run fine ?
Yes, but you will need to zero out any fuel trims you have changed on any tunning software you use.
You should have put that comment back in your other thread instead since there's no way to know what you're talking about. I just happened to see you other one so I knew.
Yes it should run fine. How long has that gas been in there though?
However, if the 255 overruns the stock FPR then you run the risk of washing down the cyl walls during break in.
I ran my car at 2k for 15 min before I went out for the break-in runs. If you do something similar then the fuel demand might be high enough to not run into problems. The overrun condition is more likely to happen at idle. Personally, I wouldn't chance it during the critical break in procedure.
Alright so i left the stock fuel pump in and put my old injectors back in. yeah i know i deffinitly got some new gas for it. Also will my turbo be okay with the stock fuel system?
Im talking about my tdo5 16g that i put in. I have no upgraded fuel system or ecu. Will it have problems.
