injectors
LordMustangGT
30
Oct 27, 2012
Bonney Lake, Washington
Simple noob qwestion, stock 1gs have low impedance injectors right?So buying a set of low impedance injectors r pnp right....
Yes low impedence 450's of its a stick and I believe 390's or something If it was auto. What injectors are you changing to and how do you plan to control them? I recommend fic and would go 850's or bigger as long as you have like ecmlink to tune them with. If your using a safc 650's are about the limit for tuning on it.
Im just going to a 20g, i have a series 1 aem, a 340lph pump, and an afpr. im not sure what injectors i want yet, i like the fic alot. I found some 1600 rc.. Something around 800-1000cc would be nice.
For a 20g I wouldn't go any less than 850's. I ran fic 850's with my 16g and had plenty of room left was probably around 60-63% duty cycle. I just got some fic 1050's to run with my hx35 next and should be plenty. Next I will probably go to a high impedence either 1250 or 1450 depending on what turbo Im running then will be either a hx35 or 40, and using q16 on the track and 92 pump on the street.
