Injector question (with pictures)
D_Eclipse9916
1,430
16
Mar 4, 2004
Vienna, Virginia
Alright I got some used FIC 650cc injectors. I need to know what gaskets or o-rings or insulators I need to get beyond what is on the injectors right now. Here are a couple pictures of the injectors..
From the pictures I would say that you need everything, top and bottom o-rings/insulators. FICs usually come with green o-rings on the top from what Ive seen. Just order direct from FIC.
From the pictures it's clear that he has o-rings, and injector sheets on the example injector.
Unless there is something wrong with them he only needs some insulators that fit those injectors. I've seen everything from dual o-rings to injector sheets to modified OEM insulators used to try and get a seal between the injector and head. I can't say what works best.
Steve
^^Now that I look real close I see the top o-rings, thanks for catching that. I was really looking for green o-rings since mine had them when I had 550s.
  • Wanted 6 bolt NT water pipe
    • chrisman287
