Injector Leak
92 AWD ECLIPSE
109
Feb 2, 2004
Knoxville, Tennessee
Hey guys, I just did a leak test on my car to see if I had any boost leaks. I did and it was the throttle body shaft seals, I replaced those, now I have a leak from, it sounds like the third injector if you are looking at the engine from the bumper. I attatched my home made leak tool to the turbo inlet, and at 8-10psi it starts to leak. I am pretty sure it is the injector because when I move it the hissing noise changes a little bit. Just wondering if it is possible to have a leak there, and what happens if i do. If I do i just need to replace the o-ring correct? Thanks for the help!
