Boost leak from injector?
Did you replace/use insulators?
Those are the larger o-ring looking rubber pieces that should be on the bottom of the injector. Those are usually what leak in the block-injector area.
Edit: ^ Beat me to it LOL
There are plastic "spacers" that go on the middle-top of the injector between the rail and the injector and there are rubber seals, referred to as "insulators" on the bottom between injector and block.
These insulators used to be made from plastic but become hard and brittle over time, which is what allows leaks to develop there. The new designs for them are all rubber so that this is less likely to occur.
If you are in a pinch, you can get them at any auto parts stores or home depot. The cheapest place would be the above link if you can wait.
http://www.dsmtuners.com/forums/articles-engine-fuel/234729-1g-2g-cheaper-fuel-injector-insulators.html
It could also be your injector pintle caps are broken or missing.
Some people have reported using rtv in that area to help fix leaks as well, but I tend not to recommend it.
If you are in a pinch, you can get them at any auto parts stores or home depot. You can also get them from the above link.
You sir, are a gentleman, and a scholar. I thank you :thumb:
