boost leak, injector question
gstowner
246
Nov 13, 2004
Creston, Iowa
Hi,
I did a boost leak test a week or so ago. Found it soming from 3 of the injectors. When I would push down on the injector connectors it would stop. So I just zip tied them for now. I believe it is coming from the injector seals. So my questions are. Should I replace just the seals or is that possible? Or should I replace the whole injectors. And are 1st gen and 2 gen Injectors the same? and the third question is aren't stock injectors 450cc?
thanks guys :dsm:
Awesome thanks man. Where can you get the seals? is it pretty much a part that you can only get from mitsu. ?
I know that they come in a Felpro gasket set but not sure if you can get them seperate. They are cheap enough at Mitsu though. I think Slowboy and some others carry them too.
another question. I was looking in Chilton last night and it said to replace the o ring and the grommet along with the bottom seal(or insulator is what they called it) Do I need to do this?
