Injector duty cycle dropping to zero
91 Turbo Mitsu
350
4
Jun 18, 2006
North Clarendon, Vermont
Okay at the moment I can't download my logs from my palm but I will tell you what happened. Today I did a third gear pull to do a log and see what was going on. When I hit about 5000 rpms,had unts of knock,timing was degrees,O2 at .80 volts,O2 trim 100% the injector duty cycle dropped to 0% and the engine stumbled,obviously. Whichway do I go to find the cause. Is this what fuel cut looks like on a logger. Right before itcut out the duty cycle was at 95%. My mods page is not correct either. I haven't installed my pump or injectors yet.Thanks for any advice and please don't flame me for not having stuff right in my mods page. I put it all in the computer and went to install everything and I have been having health issues. Thanks again for any advice. Travis
Yes, if your injector duty cycle suddenly dropped from 95% down to 0% during a WOT run, this certainly does sound like fuel cut. You may be trying to run too much boost or you may have a boost leak.
See thats the other thing. I am only running 14 lbs of boost so it isnt that hi. When it went from 95% to 0% it jumped right back up to like 90%. Probably because i let off a little. The effect was instantaneous when it happened. Thanks for the response. Hopefully someone else will chime in with more info help me.
You should be able to run 14 lbs of boost without reaching fuel cut. I would perform a boost leak test, since a boost leak can cause you to reach fuel cut prematurely.
Thanks for all the responses guys. I have been really sick the last few days so I haven't had the chance to check the car out. It seems I always forget the simple things first(boost leak). I did just upgrade alot of stuff so it is possible.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
