Injecters arnt working
LosiRacerX
41
May 30, 2004
cant tell, Texas
i used a pulse injecter tester and my injecters arnt getting any electricity, what could all b wrong, the battery is good
did you check your injector resistor pack? Its a little black box next to the battery. Or another thing to check is the little box next to the ecu. I dont know the name of it. Its a 7 pin connector though, it needs to be plugged in or the car wont run. Next make sure everything has a good ground. It will help the car run more smoothly. :thumb:
how do i check the resister pack, the car ran like 5-6 months ago, and it had no boost hoses hook up now it does and it still doesnt run
check your ecu my talon was doing the same thing then i pulled the ecu and checked it and it had a compassator that leaked if it leaked it will smell kinda fishy also there will be black crud
:thumbdown
ChicksDigBoost said:
Are you getting any spark because if your not getting either one I would put my money on CKP/CAM Sensor.
I have this problem. No spark and no signal for the injectors to spray. Is CAM sensor the same as CAS? How can I check if it is working?
i got spark, just no injecter pulse im gonna take the ecu out in the morning, how much does a used ecu got 4?
well i cant get the ecu out cuz of a stubborn bolt, ill tell ya all when i get it out and c wuts wrong wit it
