Infinity Basslink Mounting
604CruisinCroat
366
4
Feb 17, 2003
Vancouver, BC, Canada
I bought an Infinity Basslink and want to mount it horizontally by bolting it to the trunk floor. What kind of bolts/screws should I use, and shouldn't I have to fasten it on the underside with a nut? Thanks.
Actually if you just use the feet it comes with, it really won't slide around anywhere. My basslink is just sitting there up against my back seat, and it's moved very little to none at all. Every time I open the trunk I just make sure it's pushed back against the seat, and for the most part it has been. The feet do a pretty good job of grabbing the carpet. Just a thought.
If you really want to mount it though, get yourself some bolts, washers & nuts. Just put a washer on either side of the floor.
best place to put them is at a 45 degree angle in the right rear corner,but the left rear would be the next best place... passive radiator side to the rear obviously...
Just use wood screws but they have to be BARELY big enough... cut the insulation out from under teh feet leaving just the carpet if you can...
I played around with mine for many hours over many days to find what IMO is the best location for the best response.
