in need of help! please!!!!
tony070804
46
Oct 10, 2011
ardmore, Oklahoma
1995 gsx 5 speed.
Ok so I've replaced starter relay, neutral safety switch, mfi relay, plugs, ignition switch, battery, and starter!
Here's what's going on, if I try to start the car nothing happens except starter relay clicks. If I unplug relay and jumper the plug, the car will turn over and plugs will spark but that's it! Will not crank at all! I'm completely out of ideas and need some real help!
Can somebody please tell me which pins to cross to bypass the mfi relay? I really need to know if the the fuel pump works! Also can somebody please tell me what else it could be? Seriously! The only thing I can think of is the ecu is bad?
PLEASE HELP!!!!!
So is there any way to test the cam sensor? The car will turn over all day long, fuel is getting to the fuels rail, spark is good on all 4 cylinders, but injectors will not spray. Resistance is good on injectors, and 12v on the injector plugs. With that said the only thing I can think of would be a bad cam sensor so is there a way to test it?
I will check on All-Data tomorrow while I am in class. It is student car day at my school so I will be working on my own car anyways. Hope you can get it figured out!
