1.8 in need of help
nightgamer
93
Dec 27, 2009
douglass, Kansas
ok well it not so much as a surge as at 4k it bogs out if i let off the gas it trys to stall die and a odd clicking noise under load not there in Idle
edit amd when driving if i push the accl pedal to hard it seems to jump or misfire or sputter like i can barely accl
just payed 400 for the car LOL may end up swapping a 2.0 in to it if i can not fix it
so i put on new wires and plugs today started it up at 4k it boggs out droping to lower rpm and staying there the farther i push the gas pedal down till i get it floored with the gas floored the rpms are at 2k-2.7k
could timing make this happen i not so good with the 1.8s and just need it as a dd
where should i look next what could this be will be takeing a vid latter
