In-Channel vent visors for 1G
Delta2Echo
90
Mar 25, 2012
Middletown, Delaware
Do they exist? If so, where the hell can I get them?!
I didn't have much luck with the tape-on type with the 3M after a few months of higher speeds, the air flow coming up under them started peeling them off from the rear.
I have a similar problem on the driver's side wiper blades while it's raining and I'm doing anything over 65-70. The blade starts to lift right up as it sweeps.
...I'm starting to get the feeling that they don't exist...
Know it's been a couple months since you posted, but I'm right there with you man. I've been looking for these things for a while. I love having them but I hate (with a passion) the tape/glue on kind; performance, and aesthetically speaking. If you (or anyone) find a set PLEASE please please let me know! In this post or via p.m.
Ive had success using the taped on versons. The forward most part of the visor must be clamped between mirror and door. Also use a prep/cleaner spray instead of the alcohol pads.
Talking about basic rain guards that go above your window. Like the ones AVS and others make. There are the kind that go to your door frame right above your window (external) connecting with double sided tape or something similar and the kind that fit up in your window channel itself (in channel). They make external ones for 1g which I don't care for, but we can't find anyone that make the ones that fit up in the window channel.
