Im I out of luck here?
spadepro22
1,206
14
Mar 13, 2008
Seneca, South Carolina
What I have here is a ported 2g 02 housing with evoIII gaskets not matching up. My turbine housing is not ported, so will this work or Im I screwed
You can run RED RTV for that gasket. I had to do it on one of my sr20det 02 housings when I switched to a larger turbine wheel and ported hot side. I even called the turbo manufacture and that is what they told me to run.
The only time something like this would be a problem is if the o2 housing ports were smaller then the turbo's ports. I've ran stuff just like this before and just how it is and had no problems
