Freerevving
- 499
- 5
- Feb 12, 2008
Houston,
Texas
I pretty sure this has been covered before... I'm building a 1991 GSX
AND I would like some help from the members here. I don't think I absolutelyneed the help, as I'm an experienced shade-tree mechanic and tuner, but I'd like things to go smoother, quicker, and be more reliable-- especially since I'm new to building DSM's
I'm, so far, well-educated on what I need to get it together as I've been studying the car and the internet now, for about a month, before posting here. I should have a Haynes or the like by Sunday... but suprisingly the internet (and the Autozone website tech-book) has provided an amazing amount of information. So here's what I've got:
Base car: 1991 GS (clean title, no transmission)
Donor Car: 1992 GSX (no title, no engine, no ecu, no engine harness)
Extra parts: two non-turbo 4g63's. two GSX trannies. Ig turbo manifold, intake manifold, throttle body, side mount intercooler, stock internal wastegate turbo (no shaft play), bov, turbo coolant lines, boost controller and extra downpipe. I also have 1g turbo pistons and rings for the rebuild. I'm sure I'm forgetting something
ALL THE ABOVE CARS/PARTS were accquired for a total of $580
Things I need and don't have: 450cc injectors, Turbo MAF, Fed ECU, gasket set, bearing set, balance shaft elimination kit, oil lines (i think?)... no, I will not be running oil squirters until the 2nd engine's rebuild.
I have no idea where the turbo oil lines go, or weather I need to tap the oil pan. I would also like to run 8.5:1 compression... can this be accomplished by shaving the head? by how much (if there is clearance)?
I would love to get suggestions, opinions, and advice.
I also have the option of running the 92 front end... Need opinions on this also, because I'm split...
Thanks in advance, Mac
But whose going to stop you?
But she will be one hell of a beast if I ever get it to crank.
wrong is wrong, right is right... your knowledge is greatly appreciated
