ECMlink Idling at 2000-3000 RPM with AT D pin off
blujeans
78
13
Dec 15, 2018
Calgary, AB, Canada
Been wondering about this for the longest time. My DSM is an automatic with a W4A33, and whether it's cold or at operating temp the idle always stays between 2000 to 3000 RPMs when I have the transmission in park or neutral. Is this normal?
Has ECMTuning added support for automatic transmissions to the idle control in DSMLink? I don't remember them having that so the idle in Park/Neutral should be the same as what you set if the ISC/FIAV/BISS system is working.
As far as I can tell they haven't added that. Maybe they'll add it when they finally come out with V4?
Anyways I figured it out, it was my idle switch not activating properly. Just adjusted my TPS and it's all good now.
