Idling at 2-3k after BOV & IC pipes installed
Gno1316
52
Jun 22, 2002
New Jersey
95 Talon TSi AWD
w/ dejon intake & k&N filter
ok guys i just installed upper and lower IC pipes along with a type s bov. i also did the single spring mod on the bov leaving the larger spring in along with disconnecting the lower vaccum line. now my car is idling very high at 2-3k. when i first start my car (1st start since the nite before) it will idle somewhat normal just under/around 1k. after i drive it or just rev the engine up it will began to steady idle at 2k or start at 2k and work its way upto 3k. me and my dad have been goin crazy trying to figure the problem out. maybe i just cant seem to adjust the bov properly? some feed back would help.. later
im gonna disconnect my boost gauge n see if thats a problem. ill get back to you later today.
