Idle to redline
nlzn
353
4
Feb 7, 2006
Louisville, Kentucky
So after a full head rebuild i started the car today.. first key turn it started and decided it wanted to rev to redline (i turned it off before it got there).
I checked to make sure the throttle plate wasnt open and it was fully shut, started it up and did it again.
I know I torqued down the intake manifold but thats the only thing I can think of, that there has to be a leak on the intake manifold side of the motor pulling in extra air. I guess I'm going to check the torque on the bolts tomorrow again.
Anyone else have any suggestions? (im going to check the voltages on the TPS as well tomorrow via the logger)
Boost leak test from the throttle body with the throttle blade open. This will check for leaks in the intake manifold like gaskets, injector seals, Vaccum lines and that brake booster hose.
I had that happen and it was the throttle cable, not where it mounts but where it ran by the rail
Check the closed throttle sensor if that for some reason got screwed down it will keep the throttle plate from closing all the way. Also check the BISS, screw it in as far as you can and see if you still get the same problem. You're letting air in from somewhere!
hmm the CTS is the little guy on the side of the throttle body that has a spade electrical connector right?
(if so it was never connected on my car even before all this work)
Here's a pic:
All it does is tell the ECU that the throttle plate is closed or open. But you can adjust the point at which the sensor actuates. If it's screwed in too far it will keep the throttle plate open. It's just something to check and verify that it's not holding your throttle open.
No. Before I even posted this I made sure the throttle was shut (or damn close by eyeing it) with the elbow off.
Well I figured something would go wrong. After 1 month of being bare down to the block it started on the first key pull after the assembly.. I guess i just did it too good :p
YOU have to be leaking air into the mani after the Throttle body....thats the ONLY reason it would rev on its own. At least that's the only reason other than the things you have already checked.
Do a Boost leak test ASAP to be sure there is NOOO leaks on the injector seals.
Check every hose barb on the intake, check your injector seals (I had one of these get squished when I put the fuel rail/injectors back in, let in air), check tb gaskets, check intake manifold gasket.
I can't get my boost leak tester on it until this weekend (left it in my parts graveyard LOL).
I reset the throttle body today, read the voltages on the TPS etc.. I'll re-seat the fuel rail when I get home to make sure a seal didn't get pinched.
Only thing I'm confident in is the intake manifold.. i torqued it down to spec outside of the car with a new gasket with clean mating surfaces.. it's not leaking unless its cracked.
  • For sale 2g 2G AWD Fuel Level Wiring Harness
    2G AWD Fuel Level Wiring Harness $35 + shipping and paypal fees* removed from 97 TSI AWD * all...
  • For sale 2g 2G OEM Passenger Door Handle
    2G OEM Passenger Door Handle $25 + shipping and paypal fees* the seal and two mounting bolts...
  • For sale 2g 2G OEM Interior Silencer Pads
    2G OEM Silencer Pads $20 + shipping and paypal fees* these go behind the plastics to the left...
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
