2G idle problem
travisgoldkuhl
66
Nov 11, 2012
tucson, Arizona
Like title says i have a idle problem, when its warmer outside it idles up and down.
and when its colder outside (at night or early mornings) it idles anywhere from 1300 to 1500 steady. I did a boost leak test and the only leak i have is the throttle body shaft. It has fmic, big 16g, egr delete, evo 560 injectors,walbro 255 and apexi safc II. Only other problem with the car is the vss is bad and speedo isnt working.
