idle problem (I DONT GET IT!)
boostedbill
Oct 17, 2011
belmont, New Hampshire
i have a 95 talon with a 6 bolt swap when i start it in the morning it runs perfect at 1100 rpms but when it warms up it dosent idle at all. i can give it gas and it will stop at like 1400rpms and then drop to like 200rpms iv tried eveything i know and it hasent fixed it.iv clean my iac, tps, idler screw and checked for boost leaks. no boost leaks at all.
how about TB seals? the TB could be also stuck open. Is your TPS set correctly?
There may not be a leak in the system to the atmosphere, but there could be an internal leak allowing unmetered air into the intake manifold.
I see you have a 16g and 560cc injectors, but no tuning software or piggyback system. You should update your profile to help out.
If your profile is up to date you need a way to compensate for the larger injectors, SAFC ECMlink AEM standalone, megaquirt, jackal etc.
As far as finding more information on these subjects, you should just search our forums, there is already so much info.
have you checked you tune had the same problem about week ago somehow lost part of tune stupid dsm link
