Idle issues
its stock, only thing done to it is a 190 walbro and the map doesn't have the honeycombs in it. other than that she's bone stock.. OH and also I have a 1g CAS hooked up to it
its throwing check engine lights now,
p0443
p1104
p1105
p0100- this one came on because I took off the maf plug and plug it back in while running.
Update- Replaced the MAF with a stock unhacked one and it still idles like crap. Also made sure the TB was tight, that seemed to help a little as I can now rev somewhat higher but I still get the wabbababababa sound. This Engine ran great a month ago in my other car so I know the engine is good.
Does it do it under very light throttle or wot too? Try unplugging the tps to rule out a stuck idle position switch.
Fuel pump on its way out? I had a similar problem where you hit the gas and the car would bog. Swapped the pump and fixed the issue. Just a thought.
Update- Found out it was my wiring to the ECU, I forget back in the day I had a SAFC hooked up to it and it was stolen out of the bastard just hacked it. rewired it and it runs better. I still have a slight idle issues like its a boost leak somewhere.
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
  • For sale 4G63 SPAL 6.5 inch Low Profile Fan - Push
    SPAL 6.5 inch Low Profile Fan - Push $55 + shipping & paypal fees* these are great to use with...
