Spoolin4Ever
- 1,142
- 15
- Apr 24, 2005
Moses Lake,
Washington
Problem is my idle constantly goes up and down from about 1200-1500 (when warm(, when cold it also bounces up and down as it gradually reduces from 2500 down to 1500. In other words when cold it bounces from like 2500-2200, and gradually goes down to settle at bouncing from 1200-1500.
It all started when I was working on switching out my starter. I was doing that at night and I was getting frustrated. What happened is that I bonked the starter into a few things pulling it out and putting it in. I hit the ISC and the IPS, and I think I may have "bonked" the FIAV. Oh yeah, and when it hit the ISC, it actually hit the wire going to the ISC (harness).
Ever since I started it that day, I was having idle problems. Well the ISC had a bad coil, I replaced it. I also replaced the IPS, and I have tested the TPS it is good.
By the way, when I turn the Biss the idle stays the same no matter what. If I unplug the ISC< it still behaves the exact same way.
I'm trying to determine if it is the ISC wire or the FIAV.
If it is the wire, I have one from a car in the junkyard, I'd like to make a new harness setup. Where does that ISC plug into the ECU or what?
Any quick easy way to troubleshoot this?
Known good parts:
ISC
TPS
IPS
Biss
PS Even when not at idle, it will still try and maintain those RPM if I let them go down. Also when taking foot off gas it takes a while for idle to drop.
Known good parts:
ISC
TPS
IPS
Biss
Extremely annoying and frustrating. I drove it like that for about 3 months was actually almost used to it but I felt sorry for all the other pepople at the lights hehe.
THat's how I know it was the FIAV
(frickin StarMart sucks no wonder they went out of biz)..
