idiling problem please help
Talonracer06
33
Jun 19, 2004
New Cumberland, Pennsylvania
my 1991 eagle talon is a 5 speed and im having an idiling issue. when i turn the car on its ok . when i put it in gear and start to go, when i slow down or go in neutral or even shift the rpms go up and down quickly between 1500-2000 rpms. this isnt normal i dont think. i was think the tps, or the ais (automatic idle sensor) they both are located on the throttle body. there is a wire kind of on top of the throttle body that is cracked open and u can bend it and stuff. if any one has any info let me know. thanks
matt
matt
what ur talkin about is the sensor that controls the rpm, and what could be wrong w/ that is that it could be old and worn out. once this occurs, ur rpms decide to drop outta no where and ur car acts like it wants to shut off. in my case, it often did shut off. now, my initial suggestion is to try other things first, like puttin sum stp fuel injector cleaner into ur tank. if it still doesnt work, take it to a mechanic to check the sensor. that piece is worth around $200. it cost me around $250 w/ work.
:dsm: :dsm: :dsm:
:dsm: :dsm: :dsm:
Man, I had an idiling problem, very same situation, I changed many sensors, still was bad, I put new wires and it stoped. Some guys in this forum also had this problem and after they changed wires it was ok
Whatever
Whatever
u sure u changed the rpm one? the one dat sits right behind the throttle body? in fact its connected to the throttle body. maybe u just need to clean ur injectors :|
