techghost
- 196
- 0
- Feb 8, 2009
Karachi,
Asia
Guys,,
I'm verifying my CAM and Crank Pully timing for the very first time. To make it easier i rotated the engine by crank pully until i got the piston at TDC and CAM timing marks aligned.
Now the issues:
CAM:
I have stock cams and i just noticed that there were two indicators on each cams therefore i marked them WHITE. TWO are facing eachother and are aligned and other two are on the outer rings (like 180 apart) this can also been seen in the picture. Does this timing setting looks ok?
Crank:
I was not able to identify the timing marks on my crank pully, although i found two very small Cuts on both sides of the inner half of pully. So i'm assuming these are the timing marks. is it correct?
Distributor position looks odd to me.
I've attached pictures for your reference. Let me know if i'm making a mistake in marking/identifying the marks. Your help is needed.
Now the issues:
CAM:
Crank:
