Ideal fuel preasure
92Talon251
220
Sep 26, 2003
Fayetteville, North Carolina
I just installed the buschur racing FPR. I set the regulator to 36ish (basicly stock spec).
Can any one give me some advice on what to set it to for max preformance. My mods include big 16g turbo, stock fuel system, Upper Innter cooler pipe, intake, Evo III 02 housing. Thanks
:talon:
:talon:
well, i would have gone with a fuel pump first to support more boost, but about 45-50 psi on the fpr should do well.
52-54 equates to 510-518cc injectors, with a pump I keep my o2s at .94v. until you get injecors run about 52 when you get injectors turn it to stock spec so you can tune it better.
Andrew
The reason I went with the FPR over the pump was I needed the FPR since my stock one broke. I am going to upgrade the pump next I was running it on 36 ish last night I was getting decent power but it could be better. Thanks guys :thumb:
:talon:
  • For sale 1g 91-94 ignition coil
    91-94 ignition coil. Good condition. Have the weather pack that plugs into it and the stock...
  • Wanted valve body for 1GA AWD.
    Looking for a valve body for 1GA AWD.
    • kaanevrensel
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
