IC Pipe
XECLIPZEX
113
Aug 19, 2002
Cullman, Alabama
I just installed a MAFT Blow Thru Setup. I have a 3" MAS that is located right after the elbow that bolts up to the TB. I used 3" to 2" heavy duty reducer couplings on each side of the MAS. Whenever my car hits 15 PSI the d@mn coupling closest to the TB blows off. I have the coupling clamped down so tight that you cant pull it apart by hand, but when its on the car while making boost you can bet your @ss the pos will blow off and the car will die. I have been stuck on the side of the road 3 times because of this and Im tired of it. What can I do to solve this problem. Also I have noticed that the car drves different. When it is making 15psi it only feels like its about 5psi. Ever since I put this blow thru set up on all i have had is problems. Now I just want to get it running right and leave it alone. What is a good base setting for the maft with basically stock mods. I dont know if that would have anything to do with it but its worth a shot, but I am more concerned with the coupling thing so any ideas would help. :mad:
Does the piping have any sort of "bead" for the clamps to grab on to? If it doesn't you may wish to weld a small bead all the way around the end of the pipe. If it has a bead, you probably need T-bolt clamps.
The Mas And The TB elbow both have a small bead around their edges. I bought some 3" T clamps from autozone and I cant get them to fit around the coupling. Where could I find a good set of high pressure clamps.
I finally fixed my problem. I bought the Dejon Tool Blow Thru Setup thinking that would work. It didnt, so I tried everything to keep that coupling on there. Nothing worked. Finally I got some self tapping screws and screwed the coupling to the mas and it works perfect. There is no way that thing will pop off now. :thumb:
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
