KenTSIII
- 495
- 1
- May 29, 2002
Alot of people have ran very fast on 550s & a 20g. Alot of times if you go w/ a larger injector then you can't get it lean enough on race gas to get the max HP.
Originally posted by greentrbo_95gst
T3/T4 has a big advantage over shitty ported 95 manifold. Battman, i dont know what kind of turbonetics mani you've been usin...obviously none......
As far as turbos you should consider 50, 57 trim from t3/t4 or cheaper "green" With the right tuning and right setup the green will spool up by 3600-3700 and you will have a lot of boost till the redline...If you are really serious..go with Garret. I am gettin rid of my green and gettin ball bearing 62-1
good luck on your car
OK, everyone take a look at this thread to find out how it went wrong and learn from it.Originally posted by jeramie
What turbo? T3/T4 or a 20G ? Which is the cheapest setup, and can still be daily driven?
There really is no generic "BEST" turbo. That is why I offered several plus the t3/t4 hybrid with the range of options in my earlier post. Each design is a compromise between amount of flow vs. lag vs. usable boost range vs. boost transition from start of boost to full boost & so on. So based on the supporting mods and how fast you want to go vs. the amount of low speed response and lag you can put up with will determine which turbo you really need. Talk to the many vendors who build turbos every day and they help you select the "best" turbo for your requirements.Originally posted by eclipx
so, uhh... whats the best turbo?![]()
I agree.Originally posted by nineD5_GS-T
A .63 would have slower spool than the .48 but it would yield more topend. I've heard that the .48 will choke a t3/t4 setup. I would just get a .63 since it will still get boost at 3700-3800 rpm.
