i only have 1st and reverse??
gsx1990
Jun 11, 2004
copperas cove, Texas
ok one day i was driving and i went to down shift in to second and let out the clutch and there was nothing there?? so now i have only first and reverse (sometimes) no third or fourth or fifth!!! and when its in first u can feel it go in!! but when u put it were second or the other gears should be theres nothing and the shifter is all limp dick.
so is there a chance its just the shift bushings keepin it from goin into gear??
or do u think its the tranny??
thanx
Check the cables where the go into the trans. Sounds like something came loose from the shift cables.
dont worry buddy it is just the shifter, it is broken probably. There are some bushings that need tobe replaced, that is all.Trany is OK. Same shit hapend to me one day with my Alfa Romeo, I had only 3th gear :coy:
  • Wanted 6 bolt NT water pipe
    • chrisman287
