I need transmission help!
gingerbredman00
316
Jul 9, 2009
TULSA, Oklahoma
I have a 1990 TSI with a FWD transmission in it.
the numbers on the top of my bellhousing read
A60CKNH
FD2110
which is supposed to be a n/a trans?
I need the numbers from a 1g turbo trans, and to find out what year my trans is from so get a trans to match my cv axles.
I need someone to do is go read the numbers/letters off their FWD trans.
I really need some help with this:cry:
where is this 10 digit number? or can someone fix the pictures?
http://www.dsmtuners.com/forums/articles-drivetrain/244022-how-identify-90-transmisson-91-a.html
I have a 1990 FWD turbo transmission and the numbers are as follows.
stamped into the bellhousing is:
KF5M332SPZS
JW0890
Then there is another tag with a bar code that has the following:
BJW0890-SPZS
Hopefully this is what you needed to know.:)
that should help alot.. thank you
now If I could possibly get the numbers from somebody's n/a to see what trans I have?
ok so these are all the numbers that I can find on my transmission.
on the top of the bellhousing I found
A60CKNH
FT2110
to the right of those numbers I found
JA3BR46V6KZ003877
and on the bottom I found
KM206T
That long number looked oddly like a vin# to me.
The carfax pulled up an 89 mitsubishi galant!
Does this help any?
What all will I need to switch it to a FM533?
