I Need some info on the Sbr-2g20g???
wearurpjs
58
May 4, 2004
chi-town, Illinois
Well my lil t25 is on its way out :( .. It just doesnt pull like it how it used to.. My stocker boosts 16 psi daily driving and 85k miles the turbo.. Now I always think twice when a gsr or si pulls up next to me..
K first heres my mods:
hks bov
greddy hard lower/upper ic piping
mbc
hks mega flow
ngk spark plugs and wires
3 inch dp w/ 3 inch thermal catback
Bm lsd insert(not installed)
Im mostly likely getting a 20g.. For about 2 weeks now I have my heart set up on the super 20g or 20gh but from the reviews Ive heard spool is going to be a issue.. I know I need the lag but not too much lag.. Since my car is fwd I want to have killer topend, like enough topend to beat supras and modded v8s.. Now I have made my decision and I want a Sbr 2g-20g.. But I want the sbr 2g-20g with the td06 turbine and if possible keep it internally gated.. whats the difference between the td06 and td06h?? And does anybody know how much the sbr-2g20g with td06(h) go for and if I do get it should I clip and port the turbo?? and soon enough Im gonna be ordering 660's, 255, and mkiv smic but for now Im gonna keep the boost down but I juss need a new turbo soon.. any help would be greatly appreciated!!! :D
-pj
What are you doing for fuel management? You can't just throw in injectors and a pump without something to adjust the fuel. As well you're going to need an afpr.
dont even bother with a 20G it is old technology. It still uses the mitsu 7cm2 which you need to the HELL out of to fit such a lagre turbinge wheel. A TDo6h 20G will cost you $1100 for an internally wastegated w/ 38mm flapper, 90* elbow, and porting (prices from SBR). On the other hand, if you get a T3/T4 50-Trim not only does it flow more, it requries no porting, bolts up to stock e.mani and o2 housing, and cost less. I got a 50 Trim internally wastegated w/ 38mm flapper, 90* elbow for $950, plus an install kit for $100 bring the cost to $1050 which is LESS THAN a Tdo6H 20G :dsm:
As for a fuel management Im gonna use safc sorry I forgot to mention that.. Well as for the 50 trim do you know how much cfm it flows.. I really dont know that much about 50 trim.. But since its garret type turbo I wouldnt need an install kit right??.. Are the supporting mods would be the same thing as a td06h 20g?? and what rpm does full boost hit?? thanks!!!
-pj
