I need help guys!!!Its Turbo Time!!
96GST20g
Oct 1, 2009
Monroe, Louisiana
Hey guys as the title says its turbo time for my 420a. Im gettin a Turbonetics 60trim, FMIC, and Waste gate from a freind and need to know exatly what i need to run 5psi and then what i would need for 8 psi. I know i need a manifold, downpipe, intercooler piping and BOV. Im trying not to spend a whole lot on parts so if you guys know where i can get them for kinda cheap but not from ebay i want the good stuff. And i am trying to get it done before the next few car shows in my town which are oing up in a few months. So please guys send me a list on here or send me a message. So rock out guys :hellyeah: and maybe ill see you at the strip when its done :cool:
youll need a wide band, bigger injectors, (650 or higher), and a new FPR(aeromotive), and a new fuel pump...prob a 255 walboro. that will take care of the fueling.
and ebay has good stuff, you just need to do your research to make sure youre getting the good stuff off ebay. fmic off ebay is good, not so much turbos and manifolds.
Im gettin a Turbonetics 60trim....and need to know exatly what i need to run 5psi and then what i would need for 8 psi.
How about a turbo that would actually make usable airflow at that boost level? Seriously, a T25 would outflow a 60-trim at 5psi, and spool about 1500rpms quicker.
Do your homework....bigger is not always better. :thumb:
That 60 trim is gonna make your car slower than it allready is running at 5psi.
Better to sell that bi*** and get a T-25, T-28, 14b or even a 16g if you plan on bumping up the boost at a later date.
25 or 28 will do what you want fine.
Thx Daisy. Ill start lookin them up.
From what i can tell by the responces no one is reading everything. I need 5psi part in case 8psi parts are to much. I dont want to spend a whole lot of cash as i said i have the turbo, FMIC, and Wastegate. which is the most expesive of the bunch the only reason i brought up 5psi is because of price. i was hopin to keep my stock injectors for a little bit to save some cash. cause after i run it at 8psi i am rebuilding the engine with forged parts and studs etc for 22 psi. And i know how to to 4g63s just not 420a.
I still need a complete list guys
