I need help guys!!! Please
AWDTSIer
177
Aug 14, 2008
Clarion, Pennsylvania
Ok so today i was finishing up my head replacement, and doing the timing. I removed the hydraulic tensioner to pin it in place. When i went to install it i snapped the lower bolt off inside either the oil pump assembly or the block, which ever it bolts into. :beatentodeath: Do you guys have any idea on what i could do???:toobad:
sell your Talon LOL LOL
well the bolt that broke is in a block.There is nuttin much to do if the engine is in a car,because of a poor access to work with that broken bolt.What i would do.i would lift the entire engine up and the try to drill the bolt out....
Its threaded into the block still right? If thats the case and the head is sheared off, listen to cruisin and drop that side to give you a little more extra room then run an 'easy out' reverse thread thing and walk that bolt out. Sorry if I completely missed the question
