I hate electrical issues
MrChallenger360
50
Jan 12, 2008
Seattle, Washington
alright well long story short, i bought a project gst from a kid who pretty much effed everything. I installed a new tranny (expensive :cry:). finally started her up an noticed a few things. first off she was surging at idle and second i had no radiator fans. I traced the surge to a not recirculating bov so i fixed that. now car starts and idles normal. however! i still have no fans and after a few revs the temp guage was @ 50% and the surge was back!!!
so i have 2 problems. does anyone have any creative ideas for the fans? and any thoughts on the surge?
thanks
You may want to make sure that all the sensors are connected at the t-housing. Sometimes (alot of the time) are cracked or broke off and you cant tell. But you can always hardwire the fans to a switch with a fuse if you dont find to much else. Put your symptoms into the search function and se what comes up! Sorry not to much help on the idle surge but I would do a compression test or maybe a leakdown if you have the tools. That will help to find out if its your HG, but a headgasket would help it to over heat.Good luck!
i would check the fan switch it sits at the bottom of your radiator, that controls the main fan. a way to override it is get a short piece of wire open up the fuse box and locate the fan relay using the jumper wire try to make the fan turn on. to check if your a/c fan all you have to do is turn your ac switch on if everything is okay the fan will turn on if not check fuses and relays
