I Can't read a ruler, please help(pic inside)
swing lo
556
Jul 23, 2003
Jacksonville, Florida
This is tensioner with full tension and since i can't read a ruler, i need someone to tell me if the distance (between the tensioner and the automatic tensioner body) is between 5/32 and 3/16-inch(3.8 to 4.5). Somebody tell me what it is. I was looking at this picture in the manual, and mine doesn't look the same distance at all..
If your having problems reading a ruler, you should seriously reconsider your career as a mechanic. OMG
I was actually going to take pitty on you and try to explain how to read a fractional ruler but I just couldn't do it.
Metric rulers are easier to read. The more I work on my DSM the more I appreciate the simplicity of the metric system. I don't think I'd ever have really grasped and remembered anything about fractions if I didn't have to use the crap to meaure stuff and figure out if a 1/8" socket is bigger or smaller than a 3/16" socket.
Of course, I could be misinterpreting your lack of ability to read the ruler, and it might have nothing to do with that.
hakcenter said:
me and swing spoke over the phone!
Its all owned now.
And for mechanics... I'm going to have to side with omfg, the American Standard. 1 pry bar, and your set everything dismantles perfect.
How many of you guys have worked on late model american vehicles to notice how simple the design is?
I mean who ever designed the 'Timing Belt' ? Put a damn Chain in there and replace it 500,000 miles later.. jeez.
Metric system? Cars? BAH i say.
Metric system? Except Cars? ownt
Yesh, that's right........... :talon:
prolly cause a timing chain would snap at the higher rpm's that us tuners run at.
and its heavier and would add heavier rotational mass.
Same car, Same tensioner, Same result. I did that same job and my tensioner seemed to be overly tight when I pulled the pin to release the piston in the tensioner. I just left it that tight cause I had already had the damn t-belt slip once and bend up my valves. I wasnt about to let it happen again. Ive put over 6000 miles on the car since then and no problems. I'll let you know if my t-belt breaks because of overtension.
