i bought a 97 GST and have no idea what this part is
make sure you know how to use the boost controller before you drive off after installing it. :D
just like was answered earlier. thats what looks like a custom made oil catch can. 2nd is a picture of a turbo xs manual boost controller.
do you have a boost gauge to monitor how much psi your running on the car? make sure you find that out before going WOT
Cheap catch can and a cheap boost controller.
Give me a price for the shell when you blow up the car.
wow.... realy?
For the first start up cory, I would delete the MBC from the system completely and break it in on the stock psi. After you get it up and going correctly, then re-line the MBC and start to monitor off the aftermarket boost gauge to make sure whoever had it set before you was not a tard. :)
If you had to ask what those 2 parts are, I suggest you start doing alot of research here on the forums and learning as much as you can before you get into modding or anything else.
wow.... realy?
I agree. Hook it up stock, fix any boost leaks. the see how it runs. Don't run more boost than your set up can hold. I think 16 or 17 is max.
yeah before you start messing with your boost make sure you have a boost controller to monitor your boost levels and dont overboost.
