I blew up my engine! help please!!
Stainbox12
378
7
Jan 3, 2006
Panama, Central America
2 days ago i blew up my engine, i was down on the street, and my car began blowing a bunch of white smoke, but i mean, a lot (i was boosting around 13 LBS). i came home, and i checked my oil level, and it was very low. i drained the oil and it had around 2 quarters only. i checked the oil, and it looked pretty clean to me, however i took a magnet and a hard wire, and dig in to the crankcase, apparently i had some metal pieces inside, so i probably blew up my crankshaft. there was oil all over the block, so probably the head gasket blew, even though i didn´t overheat, i did a compression test today, and all checked around 150 except one that was around 20 or 30. im about to rebuild my engine, but i got a couple of questions. 1. if 1 of my cylinders checked 20 during the compression test, that means that i melted a piston? how can i check it? 2. how can i check if my crankshaft took a hit or not without removing the crankcase? my white smoke was not water, though i didn´t leak any, and i was not using any coolant at the moment. i probably drove 2 or 3 Kms before getting home. Any input is appreciated. i really need to check what i blew before starting a rebuild. :thumb:
^ Yep, you can't really check to see if you fried anything without doing that.
alright, but if 1 of my cylinders checked around 20, i know there´s something wrong, but does that mean that it melted? i thought that a melted piston would give you 0, im i right?
Think about it the only thing holding compression in the cylinder from the bottom end is the piston rings, if one of your cylinders is very low, then that cylinder the rings are most likely shot. The piston might have gone with them too, you never know until you actually pull them out. Even if they look fine from the top and bottom then side of them can still be shot to pieces. Pull them out and inspect.
-Nick
ok. theres no way to check the crankshaft either without removing the oil pan right?
