hp ??
jtjerry
80
Jul 11, 2003
Vienn, Europe
gonna dyno and tune but till next TWO weeks :( so asking you guys how much can I expect from:
1g 1990 engine
FP 28 G big turbo full ported and clipped and o2 housing
3" exhaust
550 injectors
big FMIC
hard pipies
3" GMMAF blow throu config, atmosphere vent + Translator
KN filter
255 Walbro pump
Aeromotive AFPR
MBC
with good tuning how much can I expected on wheels (or on crank)?
thanks
Jerry
btw
car is 1993 mitsu colt with FWD :thumbdown and 2200 lbs :thumb:
since you are venting you should have no problem hitting 568 whp and the fwd and light weight will make more power too :rolleyes: I love these " how much will I make " questions. :thumbdown
You didn't tell us your boost level, you didn't tell us what kind of fuel you would be using.
I want go with boost to the point where detonation will be minimal.
Highest octane on pump gas in Poland is 98. Not sure octane is calculated same in Europe as in States...
Have one more question: that boost solenoid in 1G engine recive signal from ECU to open ONLY then detonation occur?
or is based on another factors (say ECU see near cout off air flow). Asking cause have LED indicator when that solenoid is activated by ECU and it start pulse and next fuel cut occure.
I could have 16 g big if I live in normal country, but I live in euro-sh*thole community, so there is not choice. Mitsu turbo are extremly rare in Poland, friend have fp 28big with 300 miles on it so I habe 28 big ;)
    • george bromwell
    • pma1123
    • Sdcryan1
