how to run rich
420aNEWB
440
Aug 27, 2008
Eagle Pass, Texas
ok so my 420a head got ported my question is ,how to run rich in a newly built motor built for turbo but n/a at the moment?because im sure imma be running lean, I googled some of this and only found that warmer air or bigger injectors any one have any other idea what i can do? :confused:
But before doing so, either buy a wb02 or rent some wideband-on-a-stick time from a dyno shop to be certain.
Why run rich or find ways to do it ? I would say first get the turbo in and all the supporting mods on the car, then after all is said and done get yourself a wideband and tune your car from there till you get a decent a/f mix. Take your time, don't start planning way ahead.
+1
That's a nice way to foul your plugs and have you car running sluggish along with a decrease in MPG. You will be fine with the stock ecu the way it is...for now.
well im about to order an aem O2 wideband because either way or another im still going to have to buy one...
and also im not putting on a cheap turbo im saving cash for a hahn stage 2 with a 20g turbo i dont wanna think back and say ohh shouldn't have wasted money on a weak or cheap part....if i wanted right now i could piece together ebay parts with good parts..but why would i do that when the rest of my stuff is top performance.... but thanks for the advice and 96TurboGS im keeping my fingers crossed so i wont run lean... :pray:
