General how to reset safc?
TFFC
133
Apr 9, 2005
Chino, California
hi i was wondering how to reset the safc, so the car runs stock, if u reset the ecu does it reset the safc? my mods are the 2nd gen mas, 3 in exhaust, act 2100 clutch, and mbc, and safc
resetting the ECU will not reset the SAFC.
you will have to do that manually in the menu of the SAFC.
If you mean resetting it so you're not altering the airflow signal seen by the ECU, then you must do that via the Settings menu on the SAFC - resetting the ECU will not do it, as mentioned by illeffekt vr-4. In the Settings menu you can change all the Ne points on both the LO & HI Throttle maps to 0% & it will be like stock.
Note, though, that with your 2G MAF you are going to be flowing somewhere in the area of 20% more air than the stock 1G MAF & without larger injectors to compensate or using the SAFC to hide some of that airflow, you will not have enough fuel for all that air. :nono:
Just go to the "etc" menu and select "initialize". This sets it back to exactly how I came from the box. You'll have to select the number of cylinders, airflow meter type, and TPS signal range again though.
