How to remove out-put shaft ASAP
All you do is take the axle nut off the end of the axle, by the rotor, and then pry it out with a big screw driver or something. That is if you are talking about the axle. Hope this helps.
Output shaft that goes to the t-case?
You have to remove a good deal of items starting with end casing, 5 gear, reverse gear, visc. coupling, the next casing, and you should be able to pull it out from there. Remember to put the two balls back on both side of the shaft on reinstallation or the shaft will slide out. good luck (p.s. I didnt mention the tiny parts to remove)
