How to remove ignition switch?
there is the actual ignition switch bolted to the end of the key part. it is usually black in color. you won't need to remove your key part to get this off.
In the fourth and fifth picture of the link you posted. the switch portion of the ignition will be to the right side of the picture. You can just see the tab with the threaded end of the screw on the bottom side of the flange.
THANK YOU SO MUCH!
I just noticed the screw...it was just hard to see it when you are 6'5 with a massive head just not fitting down there LOL
MODS CAN DELETE
