How to install piston rings
DeNoZZo
685
Jul 6, 2008
Waterloo, Iowa
Whats the proper procedure for installing oem piston rings? IE- which way should the gap face? or is there anything else to watch out for?
I need to know how to tell if I'm installing the rings upright and not upside down. Someone please help!
rings differ from turbo to n/t. number 2 ring is the most important to install corctly the number 1 ring is same on top and bottom of the ring and the oil ring is self explanitory. the turbo number 2 ring will have a notch taken out of the bottom of the ring (a groove all the way arround). make shure the piston ring grooves are all clean. i have a picture attached because pictures are worth a thousand words and it will be easy for people to understand it better. if you have any questions pm me and ill get back to you asap.
