how to identify crower cams.
jakk220
1,320
320
Nov 13, 2010
Akron, Ohio
Got a set of cams from crowers brand new.but the problem is they didn't tell me how to identify the intake and exhaust cams. One has a purple mark and one doesn't. Also there both slotted threaded on the end. Its Sunday or id call them. One says d1 c1 and the other d2 c2.
Look at the timing gear side. Put them both next to each other. Hold them in a manner where he dowel pins for the cam gears are aligned strait up. The closest lobes to that end should be straddling the top (one set goes slightly to the left, one goes slightly to he right). The one with the lobe slightly to the right is your exhaust. The one with the lobe slightly to the left is your intake. Additionally, 1g (and maybe 2g) intAke cam has slots on the transmission side for the 1g CAS if that makes it easier.
